The truck will go into gear. After a short drive distance it will slip out of gear or just rev up. I can turn of the engine and check the fuse that has something to do with the trans because i replaced it this morning and it worked for awhile. When i turn the engine on it will go into gear and go about half a mile then it strat slowing down even if you rev up the engine.
Oct 1, 2008 at 8:45 AM
