1999 Ford F350 P/U PSD
1999 FORD F-350
BEAUTY_WALKER
I've just replaced the fuel filter in my truck, and now where the fuel drain pipe is....there is a leak, I'm losing ALOT of fuel. I've checked the release valve (is that supposed to be attached to something so it won't move around?) it is closed. I even tried to take out 1 of the 2 "O" rings at the bottom of the filter, still leaking. Any suggestions???
Dec 5, 2006 at 6:02 AM
WYNRYPEN
  • 52 POSTS
For us to be able to assist you, it is absolutely necessary for you to include the make, model, year and mileage of your car.
Dec 7, 2006 at 5:34 AM
HEY_WIRE
  • 25 POSTS
ductape
did you put fuel in the filter before you put it on if not there is a posibility that you had to much preasure and blew a line by putting fuel in the filter it takes off alot of preasure. you might have to replace the line.
best of luck
Dec 7, 2006 at 2:41 PM
