1999 Ford F350 power steering
149,000 MILES • V8 • 2WD • AUTOMATIC
JOHN K. LONG
While backing my truck out of the parking lot I all of a sudden lost my power steering. At this point it takes two hands to make a turn. Does this mean I will have to replace the power steering pump? If so, approxmiately how much does a pump cost and how much is an average cost for installation? I would appreciate a prompt answer because this is my work vehicle and I need to get it repaired promptly so I can return to work. Thank you.
Jan 30, 2008 at 11:06 AM
FLEXY5
  • 512 POSTS
Did you by chance loose the belt? If not, first check fluid levels, then leaks. If all ok, the pump is the easier to replace. Is this a diesel?
Jan 30, 2008 at 2:22 PM
