1999 Ford F350 Head lights
25,000 MILES • V8 • 4WD • AUTOMATIC
RAB12345
My high beams will not work. I changed the bulbs and checked the fuse no luck.
Oct 7, 2009 at 1:12 AM
JDL
  • 16,098 POSTS
welcome to the forum. Does the high-beam indicator on the dash work? Did you use a testlite on the high-beam fuse circuit? fuse 16-- 15 amp, junction box. Fuse circuit goes hot when you turn on high-beam.
Oct 7, 2009 at 7:49 AM
RAB12345
High beam indicator comes on and I have power at the fuse.
Oct 7, 2009 at 10:05 PM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_ford_f_350_1.jpg
Did you check the voltage circuit at the lamp, high-beam, lite green wire with black tracer? If no voltage, find splice s113 and check for voltage there.
Oct 8, 2009 at 2:47 AM
