1999 Ford F350 Engine Makes ticking noise when under load
51,020 MILES • V8 • 4WD • AUTOMATIC
GSAWDY85
I work for the U.S Navy, and I am trying to determine what a ticking sound is coming from the engine of a Ford F350 Dulley. It does not make this noise while at idle, but when put into drive and driven the sound becomes noticable from inside the cab. I thought at first it was an exhaust leak, but it does not make the sound when at idle and I am under the hood. I have tightened all exhaust connetions to and from the turbo, manifolds etc. Again the engine only makes the sound when under load.
Sep 8, 2010 at 4:39 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Dose this tick start from cold or is it more evident when up to temp?
Mark (mhpautos)
Sep 11, 2010 at 3:26 PM
