ok the other night the truck started loosing power then finally dies. we cleaned the fuel water seperator and changed the filter. got it running for a total of 3 miles then same problem. this time we played hell getting it running, tried blowing compressed air into the tank limped another mile then shut her down. what i noticed is the manual says the electric fuel pump on the frame should only run for 2 seconds? ours runs 20-30 seconds. also there is two small metal lines coming in to the fuel/water seperator on the pasenger side that seem to be extremely lose? especially the forward line. the old filter was really bad and caked with a reddish rust color. when i open the bleed valve there seems to be alot of pressure in the housing? something i should add is when this first happened we ended up smoking the starter and locking it up. theres a new one installed. but at first the solanoid on the fire wall would not activate the starter until we jumped the terminals. but after that it started working again.
Aug 30, 2009 at 1:29 AM
