1999 Ford F350 clutch
165 MILES • V8 • 4WD • MANUAL
OLDVIKING
I just had the clutch and pressure plate replaced along with the slave cylinder and now the vehicle won't go into gear.
Jan 9, 2008 at 4:50 AM
  • 31,937 POSTS
Hi there,
Do you have clutch hydraulic pressure? if not check fluid & master cylinder for leaks as well. Start there.
Mark (mhpautos)
Jan 9, 2008 at 9:59 AM
OLDVIKING
[quote:045b86e2f1="mhpautos"]Hi there,
Mark (mhpautos)[/quote:045b86e2f1]
Thanks for the response. I do have hydraulic pressure clutch. I got the vehicle into gear after pumping the clutch repeatedly by hand. Air in the line was the problem. Unfortunately, there is no bleeder valve so the only way to get air out of the system without replacing the complete system is to pump the pedal numerous times.
Jan 9, 2008 at 11:22 PM
