1997 Ford F350 master cylinder
SPERRY2631
Brakes problem
1997 Ford F350 V8 Two Wheel Drive Automatic
I pulled into a parking spot the other day and had brakes, when i pulled out an hour later, there were no brakes at all. when i checked the fluid, it was full. two days later i am getting ready to replace it and it was dry. there is fluid dripping from the tire. what should i be looking for?
Nov 12, 2008 at 2:58 AM
DAVE H
  • 13,383 POSTS
remove wheel where you see fluid .. check pipes and cylinder's and replace as necassary .. you will have to supply us with which type of brake system you have ie. front pad/rear pads .. front pads/rear shoes and from which wheel you have the leak .. if you require more info ??
Nov 27, 2008 at 1:41 PM
