1997 Ford F350 Heater Core
MIKEY57
  • 1997 FORD F-350
  • V8
  • 4WD
  • 255,000 MILES
How hard is it to replace the heater core in this year model truck?
Thursday, November 27th, 2008 AT 8:32 PM
DAVE H
  • 13,384 POSTS
HEATER CORE
Removal & Installation
Carefully release cooling system pressure by turning radiator cap to first stop. Tighten radiator cap. Drain cooling system. Disconnect heater hoses and plug hoses. See Fig. 1 . Remove glove box for access. Remove Rear Anti-lock Brake System (RABS) module mounting screws and move module aside. Remove 7 screws attaching heater access cover to plenum. Disconnect vacuum source. Leave vacuum harness attached to cover. Remove cover. Remove heater core from plenum. To install, reverse removal procedure.
https://www.2carpros.com/forum/automotive_pictures/266999_heat_2.jpg
Thursday, November 27th, 2008 AT 8:46 PM
