1997 Ford F350 fuel injection system
80,000 MILES • V8 • 2WD • AUTOMATIC
PARYINC
truck wouldn't start--gas filter clogged --changed filter-
truck will not start (not getting fuel from tank) I removed filter after trying to start and no fuel was in the line--as far as I know the clogged filter was the problem--does the system have to be bled to start or should the pump fill the system on its own
Sep 10, 2008 at 4:43 AM
PEAR69
  • 1,482 POSTS
Is the fuel gas or diesel?
Sep 10, 2008 at 4:55 AM
PARYINC
gas engine
Sep 10, 2008 at 5:05 AM
PEAR69
  • 1,482 POSTS
Yes, the system will fill on its own--no need to bleed. Check the fuel pump to be sure it is working. If it is working, check the fuel pressure with a pressure gauge -- what is the fuel presure?
Sep 10, 2008 at 5:09 AM
