the over drive light comes on and the overdrive light switch starts blinking
1997 FORD F-350
160,000 MILES • V8 • 2WD • AUTOMATIC
TONY1224
first the truck won't start with the ignition,to start i have to open the ignition switch,then go to the front of the truck and hot wire the starter solenoid,once the truck starts the abs light comes on. as i drive down the road the transmission don't want to shift. and starts to jump low to high, and vice , versa. then the over drive light comes on and the overdrive light switch starts blinking. i checked all the fuses,tried a new ignition switch and still the same,so i took out the new ignition switch and put back the old one.i don't know what else to do. thank you.
tony
May 20, 2008 at 12:55 AM
SQM
  • 6,383 POSTS
It sounds like the starting issue is due to a faulty starter solenoid. As you are able to start it by crossing the solenoid posts, it means there is a malfunction within the solenoid.
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
As for the shifting issue, it could be due to low or contaminated fluid. It can also be due to faulty pressure control solenoid.
Oct 15, 2021 at 3:19 PM
