1996 Ford F350 Drivers Side Rear Window Regulator Removal
1996 FORD F-350
160,000 MILES • V8 • 4WD • AUTOMATIC
JAMESCWELCH
How do you remove the drivers side rear window regulator
Sep 9, 2010 at 6:23 AM
BILLYMAC
  • 2,204 POSTS
remove the door panel.
remove rubber window guide from top of door panel if equipped.
remove bolts holding glass to reg
block window up or remove.
remove bolts or rivets remove reg assy
Sep 19, 2010 at 2:40 AM
