1996 Ford F-350 Two Wheel Drive Automatic 133, 00 miles
When I put the truck into park then I am backing up, going out of drive to either park or reverse somethings the truck will not go back into drive. I will have to put it down into first then second, then drive. When going down the road even with a load there is no slipping. This does not happen every time.
And it does not seem to make a difference if the truck is hot or cold
SPONSORED LINKS
Tuesday, October 12th, 2010 AT 10:51 AM
