1996 E 350 stalls
RCK1953
  • 1996 FORD F-350
When your driving down the road it stalls. Leave it sit for 15 to 20 minutes and it restarts. Also when you try to get trouble codes with a scanner the scanner says that it does not recieve information from the computer. We tried to retrieve codes from the OBD 2 port also tried the global from OBD2 it said the same tried to retrieve codes from the OBD 1 under the hood and it said it cant retrive information from computer. Thank You
Monday, June 25th, 2007 AT 4:13 PM
RCK1953
  • 5 POSTS
"rck1953"]when your driving down the road it stalls. Leave it sit for 15 to 20 minutes and it restarts. Also when you try to get trouble codes with a scanner the scanner says that it does not recieve information from the computer. We tried to retrieve codes from the OBD 2 port also tried the global from OBD2 it said the same tried to retrieve codes from the OBD 1 under the hood and it said it cant retrive information from computer. I have found that thi OBD 2 port is non functional only the OBD1 will retrieve codes manually and the one I get is for low voltage on egr. Also changed PCM relay and it still stalls if you try to start it before 15 - 20 minutes has passed it fires off once doesnt start. Once it has restarted if you leave it run it doesnt die again until you have shut it down. Thank You
Thursday, June 28th, 2007 AT 10:25 AM
