1995 Ford F350 engine shuts down after idling 2-3 minutes
1995 FORD F-350
DIESELFOREVER1
Engine problem
1995 Ford F350 V8 Two Wheel Drive Automatic 160k+ miles
I have a 95 ford f350 diesel PU 7.3 liter engine. It will start up stay idled for a few minutes begin running rough and shuts down. changed fuel filter.
any suggestions. doesn't really stay idled long enough to over heat. I'm stumped.
Feb 12, 2008 at 9:31 PM
DAN CHURCHILL
  • 6 POSTS
I have a 1996 Ford F350 If your diesel engine stalls on a regular basis. I would replace the camshaft sensor. It is located right below the water pump it has one bolt and one wire harness. less than a 20 minute job. part cost approx. $25.00
Feb 15, 2008 at 7:32 PM
REYNOLDT
  • 12 POSTS
Water in fuel? have you drained the water collector. Is the port open to allow draining? They tend to rust and clog up and water can't escape. Batteries both charged up good?. Need to disconnect each and charge individually. Just acouple of suggestions from a 94 7.3 350 turbo-DI owner. I had the same problem
Feb 23, 2008 at 8:02 PM
