1996 E 350 5.8 220000 miles automatic
RCK1953
  • 5 POSTS
rck1953"]when your driving down the road it stalls. Leave it sit for 15 to 20 minutes and it restarts. Also when you try to get trouble codes with a scanner the scanner says that it does not recieve information from the computer. we tried to retrieve codes from the OBD 2 port also tried the global from OBD2 it said the same tried to retrieve codes from the OBD 1 under the hood and it said it cant retrive information from computer. i have found that thi OBD 2 port is non functional only the OBD1 will retrieve codes manually and the one i get is for low voltage on egr. Also changed PCM relay and it still stalls if you try to start it before 15 - 20 minutes has passed it fires off once doesnt start. Once it has restarted if you leave it run it doesnt die again until you have shut it down. I have also replaced the ignition module it runs better now but it still shuts down. Thank You
Jun 29, 2007 at 1:46 AM
RCK1953
  • 5 POSTS
Well guys I figured it out myself I was the pickup in the distributor. It starts and runs fine now. Without and good answers it took a long FRRRRRUSTRATING time and many times of sitting and waiting for it to restart. This vehicle is for a poor food ministry that relies on this vehicle every day.
Jun 30, 2007 at 4:55 AM
