1995 Ford F350 slipping
127,490 MILES • V8 • 2WD • MANUAL
MICHAEL SMITTY
In fourth and fifth gear the rpm's rev up, and the truck stops pulling when I hit about 1500 rpm's
Nov 28, 2008 at 8:45 AM
DAVE H
  • 13,383 POSTS
you have a faulty clutch i'm afraid .. it needs replacing ... i suspect it's the pressure plate and it will only get worse ?
Slipping
Pressure springs worn or Release pressure plate
Oily, greasy or worn facings...Clean or replace clutch disc
Incorrect clutch alignment...Realign clutch assembly
Warped clutch disc or pressure plate....Replace damaged components
Binding release levers or clutch pedal...Lubricate and/or replace release components
Nov 29, 2008 at 1:01 PM
