1995 Ford F350 Fuel leak
1995 FORD F-350
142,000 MILES • V8 • 4WD • MANUAL
GBOYLES
I'm out of ideas for what may still be causing a slow disel fuel leak. I have replaced the fuel pump and hoses, added new metal washers at the banjo fitting and noticed a small leak at the vacuum sensor (fuel restriction sensor) and replaced that and still am seeing disel in the valley but cannot visable see fuel leaking even with mirrior and flashlight. Should I place a new gasket at the fpr? I can't see from any angel but should I assume the drain valve is leaking from below? The fuel fillter canister appears to be OK.
Apr 20, 2009 at 1:20 PM
MOBILL122
Mine developed a leak from the fuel return line, driver's front side, to valley side of valve cover, right in the corner at front of valley. Was really hard to get to, but we did manage to fix without taking off half the top of engine.
Jun 9, 2009 at 12:12 PM
