1995 Ford F350 fuel filter
1995 FORD F-350
9,200 MILES • V8 • 2WD • MANUAL
DOODLEBUG5172
How do you change the fuel filter in a 1995 Ford F-350dump truck
Jul 25, 2009 at 7:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
what size engine? 5.0L , 5.8L etc..? Gasoline or diesel engine?
Jul 25, 2009 at 7:38 AM
DOODLEBUG5172
5.8L gasoline
Jul 25, 2009 at 7:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
it is located under the vehicle, driver side, below bed area, front of fuel tank, mounted on chassis in fuel line. will need special service tool to disconnect the fitting at end of filter. relieve fuel pressure, disconnect fittings and remove filter.
Jul 25, 2009 at 8:08 AM
DOODLEBUG5172
Thank-You very much for the quick answer............That what i thought ....a service tool.........thanks again.......Shari
Jul 25, 2009 at 8:26 AM
