1993 Ford F350 transmission problem
1993 FORD F-350
200,000 MILES • V8 • 4WD • AUTOMATIC
GEOWLS
Hi.
I have a 93 Ford, F-350, 4x4, 7.3 non-turbo, with automatic transmission, and 200K miles. 100K miles on transmission. When I start it up and put it in drive, it doesn't move. Then, just by pressing the O.D. button, (overdrive off) trans kicks in and away we go. Run it up to speed, let off the throttle while turning O.D. back on, and your in O.D.
As long as you don't over throttle, it drives just fine in O.D. But, if you over throttle, it kicks out (like you're in neutral). Switch the O.D. back off and the trans kicks back in. Run it back up to speed, let off, turn O.D. back on, and you're going again. Reverse works whether the O.D. is on or off.
Any ideas?
P.S.- I've been driving the truck this way for about
5,000 miles.
Thank You, in advance, George ( :? geowls)
Nov 30, 2007 at 6:03 PM
FSTRANGER302
  • 117 POSTS
[quote:ca3571ca20="geowls"]Transmission problem
1993 Ford F350 V8 Four Wheel Drive Automatic 200000 miles
Hi.
Any ideas?
5,000 miles.
Thank You, in advance, George ( :? geowls)[/quote:ca3571ca20] hello, it sounds like you have a torque converter problem the overdrive is contorled by the torque convereter. hope this helps let me know pat
Dec 5, 2007 at 4:35 AM
