I have a 1993 ford f350 7.3 deisel the truck is having trans problems, i've owned the truck for about two years 2nd owner and this is the third e40d trans, the overdrive light will flash and it sends the trans into a frenzy, the truck has a factory banks trans shifting unit for towing, every shop i send it to resets the computer and tells me I need another trans, put one in two days ago and it still has this problem, its not using 1st or 2nd gear when light flashes, when i first start it the thing work well no slipping ever. Help
May 7, 2008 at 1:03 AM
