1993 Ford F350 battery not charging
130,000 MILES • V8 • 4WD • MANUAL
CLD80440
The battery on my F350 is not charging. I've checked and cleaned all cables. Does this mean I need to replace the alternator or is there anything I should be checking first?
Jun 10, 2008 at 6:53 AM
MERLIN2021
  • 17,250 POSTS
Use a voltmeter and test across the battery with engine running, should get 13.8-15 volts, if not you can try grounding the "F" field screw on the back of the Alternator for a few seconds to see if it comes up, if it does the voltage regulator is gone..if not the alternator, either way your has an integral regulator, I think!
Jun 10, 2008 at 6:58 AM
