1992 Ford F350 No spark
1992 FORD F-350
367,000 MILES • V8 • 2WD • AUTOMATIC
LUCYGIRL
Dash panel dimmed and exhaust popped and engine stumbled and died.
Have no spark. Found blown diode in power distribution box. I can not find this diode module on line???
outside is marked "fovf-14A604-AA"
Will replacing this module fix the problem?
Thank you
Jan 13, 2008 at 11:34 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e27be9b953="lucygirl"]Electrical problem
1992 Ford F350 V8 Two Wheel Drive Automatic 367000 miles
Thank you[/quote:e27be9b953]
did you mean relay
check with local part store
they can cross the # s for you
Jan 13, 2008 at 11:37 AM
