1990 Ford F350 fuel guage not working
1990 FORD F-350
BIGPAYNE
Electrical problem
1990 Ford F350 6 cyl Two Wheel Drive Manual
OK I have a truck with a steel tank, I have unplugged the sending unit wires and the gauge goes past full, I grounded the power wire and the gauge goes less than empty. I removed the pump assembly and plugged back in and it works great. reinstalled and it does not.
removed and connected hangar assembly to a ground wire to the batt. and it works. If I hold the assembly to the tank it quits working! Even if it is in the tank, as long as it is sitting on the rubber gasket it works, if I put the retainer back on it quits??
Feb 6, 2010 at 2:05 AM
2CARPRO JACK
  • 11,533 POSTS
Use a meter and see if the wires are shorting out to the sender assembly where they pass through the top.Is the tank grounded as well? Is the baffle in the tank broken loose causing the float to stick in one position?
Feb 8, 2010 at 12:07 AM
BIGPAYNE
thanks figured it out the two wires had been cut back in the harness a ways and reconnected backwards, letting the sending unit work out of the tank and shorting to ground when in the tank
Thanks
Feb 8, 2010 at 9:21 AM
2CARPRO JACK
  • 11,533 POSTS
Good find
Feb 8, 2010 at 12:51 PM
