1990 ford f350
LARRYMECH
2. Current odometer reading about 98,000 (approx)
3. Stick Shift or Automatic Transmission (stick)
4. Strange sounds or smells (if any)
5. Fluid leaks (if any)
6. Past repair history (if applicable)
pickup will surge at idle, jerks like it running out of fuel and acts and surges in low gear 35to 40 lbs. fuel pressure with the key off 35 lbs. with key on have changed fuel filter and spark plug wires
Oct 26, 2007 at 4:13 PM
MERLIN2021
  • 17,250 POSTS
Check for vacuum leaks Larry! Get a can of spray gumout, spray vac lines and around the intake, if the idle changes, you found the leak. Use this guide when the engine is cold only
Please go over this guide and get back to us.
Oct 27, 2007 at 2:24 AM
