1989 Ford F350 truck won't run
1989 FORD F-350
220,000 MILES • V8 • 2WD • AUTOMATIC
DARRYL DIROM
truck will idle but can't accelerate, it starts pinging or knocking then truck come to a stop and stales , it starts up right away, It also sounds like it's flooding it self . I ve changed map sensor, ignition module, fuel pump relay , fuel pump relay socket, cap and rotor ,plug and wires and fuel filter ,still won't run driving me nuts
Feb 4, 2008 at 3:47 PM
Try checking the fuel pressure and ignition timing to include the throttle position sensor.
Feb 4, 2008 at 3:55 PM
