I have a 1989 F-350 and I have not been able to get it fired up. I think it is some type of fuel issue because it is turning over and when I spray a decent amount of starter fluid it will fire for about 3 seconds then stop. I have checked the Fuel pump relay under the hood. Although when I turn the key the electric pump should turn on for about 2 seconds then shut off, which I do not hear. I was also thinking it could be a clogged fuel filter as the vehicle sat for a while but started with not much fuel. I was also thinking of checking the inertia switch but I am not sure where the fuel pump or inertia switch are. Suggestions and advise are highly welcomed. Thanks
Feb 12, 2009 at 4:55 AM
