1989 Ford F350 need help
FPOHL93
Transmission problem
1989 Ford F350 Four Wheel Drive Manual
how do i change out a clutch...and a transmission to my truc k
Dec 6, 2009 at 11:40 AM
BILLYMAC
  • 2,204 POSTS
raise and support truck on suitable stands.
remove driveshaft.
remove shifter
remove transfer case
remove starter
removecrossmember,support trans with jack
remove all bellhousing bolts
remove clutch line or rod
lower jack pull trans back
remove pressure plate bolts
remove clutch.
replace clutch slave and master and pilot bearing.
Dec 29, 2009 at 12:40 PM
