Raise and support truck on suitable stands.
Remove driveshaft.
Remove shifter
remove transfer case
remove starter
removecrossmember, support trans with jack
remove all bellhousing bolts
remove clutch line or rod
lower jack pull trans back
remove pressure plate bolts
remove clutch.
Replace clutch slave and master and pilot bearing.
SPONSORED LINKS
Tuesday, December 29th, 2009 AT 8:40 PM
