1989 Ford F350 Charging system failing
189,000 MILES • V8 • 2WD • AUTOMATIC
FRANK RAMIREZ
My batteries wake up dead. I have replaced alternator, voltage regulator, and 1 battery that was bad, however the batteries do not keep charge. The voltage reads fine on dashboard control. I do notice that when I connect the positive clamp to my battery charger and then go to connect the negative clamp, a small spark gives off. I have checked all fuses and all are fine. I have checked all lights including domes, glovebox and lighter and these are not causing the lost charge. I suspect it must be a short under the hood but need help so I know where to start looking.
Nov 15, 2009 at 7:33 AM
MERLIN2021
  • 17,250 POSTS
You may have a parasitic drain check for it like this:
http://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Nov 15, 2009 at 7:36 AM
