(Before people start replying withh "throw that P.O.S. away" I should say that the 14ft. box in the back is painted with some incredible artwork, so I need to keep this truck running.)
So here's the facts:
1) Fuel guage is broken, and I'm afraid I've run the truck out of fuel a few times now.
2) This time I had fueled up rather recently, so either something else went out or somebody siphoned fuel out.
What I tried:
1) Put 5 gallons of fuel in
2) Took off engine cover and sprayed starter fluid as I turned the key.
3) Replaced batteries
4) Replaced starter (just happened to go out while we were trying to restart it)
Another note-- I DO have to spray starter fluid every morning to get the truck to run. I replaced all the glow plugs 4 months ago, but they still would not get the truck to start without the ether.
Thanks for the help-- if you'd like to email me directly-- its ArtistMoving@gmail.com
thank you!
Also, if the answer is to - check the glow plugs and replace if blown-- could you also tell me what else to fix so that I can start the truck normally and don't just blow them out again by starting with ether. I do make sure I turn the key on for 5-10 seconds before starting.
What I tried:
thank you!
Oct 5, 2009 at 4:22 AM
