1988 Ford F350 NO Start
CIRCLELB
Electrical problem
1988 Ford F350 V8 Two Wheel Drive Automatic
460 Motor, Will Crank but will not start. Changed Distributor, Cap, rotor, Plugs and wires, Ignition Switch under Dash, Coil. Can you Help
Feb 2, 2009 at 1:42 PM
  • 75,988 POSTS
Does it have spark and fuel pressure?
Feb 2, 2009 at 2:06 PM
CIRCLELB
[quote:5bc5113ce4="rasmataz"]Does it have spark and fuel pressure?[/quote:5bc5113ce4]
NO spark to the distributor, Did have Fuel Pressure.
Feb 2, 2009 at 11:43 PM
CIRCLELB
No spark to the distributor. check coil w/ometer.
+ to -- was 0.00v Center post to + was 7.25v
Feb 3, 2009 at 12:05 AM
  • 75,988 POSTS
You need to measure the coil's primary and secondary resistances See below specs. If okay check the distributor pick up coil and then the ignition control module
IGNITION COIL PRIMARY RESISTANCE
Tips Click a link to view tip
Tech1Tip: NO VOLTAGE TO COIL OR ECC RELAY
With ignition switch in "OFF" position, disconnect ignition coil connector. Inspect connector for dirt, corrosion or damage. Measure resistance across ignition coil positive and negative terminals. See Fig. 4 .
Resistance should measure .3-1.0 ohm. If so, ignition coil primary circuit is okay. Proceed to IGNITION COIL SECONDARY RESISTANCE test. If resistance is less than .3 ohm or greater than one ohm, replace ignition coil.
With ignition switch in "OFF" position, disconnect ignition coil connector and secondary wire from coil tower. Measure resistance between negative coil terminal and coil tower. See Fig. 4 .
Resistance should measure 6500-11,500 ohms. If so, ignition coil is okay. Proceed to WIRING HARNESS test. If resistance is less than 6500 ohms or greater than 11,500 ohms, replace ignition coil.
Feb 3, 2009 at 6:28 AM
