1988 Ford F350 EGR Valve
TITCH017
Engine Performance problem
1988 Ford F350 V8
Could you please tell me where the EGR valve is located in our 1988 Ford Truck F350?
Apr 19, 2010 at 7:31 AM
MATHIASO
  • 1,209 POSTS
Hello titch017
Is 1988 Ford Truck F350 1 ton P/U 4WD 7.5L FI 8cyl your truck? or it is different than this?
Apr 20, 2010 at 2:13 AM
TITCH017
[quote:e35bee23b0="mathiaso"]Hello titch017
Is 1988 Ford Truck F350 1 ton P/U 4WD 7.5L FI 8cyl your truck? or it is different than this?[/quote:e35bee23b0]
Hello mathiaso
Yes that's the one. It lost all power while pulling the RV and used even more gas than ever. We took it and had the Cat replaced and they said we also need a new EGR valve. It pulled a better after, but we want to see if we can't replace that valve ourselves, if we know for sure where exactly it is.
Apr 20, 2010 at 3:04 AM
MATHIASO
  • 1,209 POSTS
Yes you can. It is located under hood, center, upper engine area, passenger side of intake manifold with the egr sensor on the top of it. REMOVAL : Disconnect the EVP sensor wiring.
https://images.2carpros.com/forum/automotive_pictures/46384_1_10.jpg
Disconnect the exhaust gas inlet tube
https://images.2carpros.com/forum/automotive_pictures/46384_2_8.jpg
Unbolt the EGR from the engine
https://images.2carpros.com/forum/automotive_pictures/46384_3_4.jpg
Scrape the gasket surfaces clean without scuffing them
https://images.2carpros.com/forum/automotive_pictures/46384_4_1.jpg
Make sure the passage (hole where the marker is )leading to the intake is not plug if it is unplug it .I believe that where the problem is.spray carburetor cleaner and unplug it it with a small screwdriver until it free of hard carbon deposit
https://images.2carpros.com/forum/automotive_pictures/46384_4_2.jpg
To install: # Attach the EVP sensor to the EGR valve. # Install the EGR valve to the engine with a new gasket and tighten. # Attach the vacuum line to the valve. # Connect the EVP sensor wiring. # Disconnect the exhaust gas inlet tube. # Connect the negative battery cable. If you have questions or difficulties, feel free to contact.
Apr 20, 2010 at 5:57 PM
