Clutch suddenly started slipping while driving at higher speed and seems harder to disingage.
Dec 14, 2007 at 5:29 AM
MERLIN2021
✓Experienced Mechanic
Pressure plate needs work or you have grease or oil on the friction plates...
Dec 14, 2007 at 9:19 AM
Yep, this means the clutch disc is worn out, or you might be able to adjust the slave cylinder which can give you more life out of the clutch, if the slave has play this will not help but it is worth a try. This video can help
