1982 Ford F350 truck sterring swayes
1982 FORD F-350
140,000 MILES • V8 • 2WD • AUTOMATIC
SLHARM1
what should i check for a swaying problem in sterring? when driving down the road you get play in the steering colume and the truck swayes trying to compinsate for this is there a way to tighten to colume steer or is it in the steering box,what should i look at?
Sep 3, 2010 at 5:37 AM
BILLYMAC
  • 2,204 POSTS
have an assistant help you
with engine off key on have helper move steering wheel back and forth only move wheel through steering wheel play. as in move wheel when you see wheel start to move go the other way. look at the tie rods no play steering arm gear box anywhere a part is moving and the wheels are not is bad
Sep 19, 2010 at 3:01 AM
