1971 Ford F350 oil pressure
100,000 MILES • V8 • 2WD • MANUAL
GORDONITIS
Yesterday the oil pressure pegged at idle then went to down at driving rpm. Every time I stopped it pegged then dropped to near normal reading at driving. I thought the filter by-pass might be plugged but after a filter change the problem is the same.
Sep 25, 2008 at 8:16 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge-if normal replace the oil pressure switch-if abnormal could be the oil pump/engine bearings
Sep 25, 2008 at 8:24 AM
