Starter engages when i turn the l headlights on
FORD F-250
3HRTOUR
Hello I have a 1987 f250 dieseil lariat.
After charging the battieres last the starter engages when i turn the lheadights on. futher more.. The ingition works fine and the truck starts the way it should but at night when i turn the lights on it engages the starter... I cant turn the lights on while the motor is running or the starter grinds aganist the flywheel or something.
Thanks for the help :)
Sep 6, 2007 at 4:20 AM
MERLIN2021
  • 17,250 POSTS
Well I guess we can toss the key?
No really....have you checked the headlights while cranking with the key? I'd say there is a short in the steering column...
Sep 6, 2007 at 7:09 AM
3HRTOUR
hey, Thanks for te response... among other ideas i was also think the steering column... mostly because the hazzards dont work either and blow the fuse.. they are also in the steering column.
I will take a look tomarrow.
Thanks again
Sep 6, 2007 at 4:41 PM
