Sounds as if you have a fuel restriction problem, an accelerator pump discharge that is not correct, or float level. Be sure the accelerator pump rod is adjusted correctly. You should be able to see steady squirt of fuel into the throttle body when you depress the throttle rod. Be sure your spark plugs have the proper gab about.35. If this does not help, be sure that your timing is correct, & the firing order is correct. Made that mistake myself years ago! Good luck.
SPONSORED LINKS
Wednesday, July 5th, 2006 AT 10:58 AM
