Malfunctioning Turn Signal
ECICITSYM
Hello. New to the forums.
The left turn signal on my 1996 Ford Thunderbird LX, V8 4.6L engine, 125000 miles has begun to malfunction.
When I turn it on, the indicator on the dashboard flashes very rapidly. Outside, only the front signal is flashing and rear signal does nothing.
The right turn signal is fine.
I have checked the fuses and the bulbs. They're both working, but I replaced them anyway.
So, now I turn to the forums for help.
Any help is appreciated.
Jul 13, 2006 at 3:11 PM
TAURUSWHEEL
  • 718 POSTS
Rapidly flashing indicator is a sign of a problem in the circuit, maybe the ground is bad, or the bulb socket is bad, you've already replaced the bulb, which is usually the problem,, are they the 2-filament type also containing the taillamp ??? Also in rare instances the turn signal switch itself can be at fault
Jul 13, 2006 at 11:16 PM
