Intermittent Door Locks
BLUEIDTXAN
I have a 2000 F 250 Super Duty (7.3 Turbo Diesel) with 99,600 miles, automatic transmisison, power windows, and locks.
The Problem is that I had an alarm system put in this past winter,and when the weather is Cold, the locks Worked fine. But when it started warming up they quit working. They will work VERY occasionaly. I took it back to the car alarm place and he thinks its the Body control module. I had a Python alarm system installed.
I checked the Fuse and it was a little bit corroded so I changed that still same problem.
Any Ideas
Blue in Fort Worth (wheres its HOT most of the year)
Jun 28, 2007 at 1:01 PM
BLUEIDTXAN
They are factory Door locks and windows.
I am trying to lock/unlock from the inside and results are same with either driver or passenger door lock switch.
Fuse was in the power distribution box under the hood. (#26 if I remember right) 20A as stated in the owners manual.
Remote is the python... no keyless on this trcuk from factory.
Hope this information helps
Blue
Jun 28, 2007 at 9:26 PM
