HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-250
Electrical
Ignition Switch
Replace/Remove
SPONSORED LINKS
Ignition Switch Removal
STVNSTEVIET
MEMBER
FORD F-250
1989 F-250, 5.0 engine, auto trans, 77000.
Quest: To remove ignition switch do I need to remove steering wheel?
Thanks for your help! Happy Holidays!
Tuesday, November 27th, 2007 AT 10:58 AM
BLACKOP555
MECHANIC
You should be able to remove it after you take out the ignition tumbler, by removing the bezles that hold it in place.
SPONSORED LINKS
Wednesday, December 5th, 2007 AT 8:01 PM
Please
login
or
register
to post a reply.
Related Ignition Switch Replace/Remove Content
How To Remove Ignition Lock
I Have The Upper Column Housing Removed, And Have Removed The Support Brackets From The Lower Housing, Have Also Removed The Shift Tube...
Asked by
Jason Roskelley
2 IMAGES
1992
FORD F-250
1981 Ford F250 Replacement Of Ignition Switch
I Need To Replace My Ignition Switch. I Want To Do It Myself. I Need To Know How Its Done.
Asked by
f250
1 ANSWER
1981
FORD F-250
1989 Ford F250 Replacing Ignition Switch
I'm Replacing The Ignition Switch (electrical Switch On The Column, Not The Key/tumbler Part). The New Switch Came With A Stiff, Pre-...
Asked by
bobdoss28753
1989
FORD F-250
1975 Ford F250 Ignition
Hey New To Forum Whats Up Everyone My 1975 Ford F250 Wont Start All I Get Is Clicking Noise Changed Ignition Switch, Starter...
Asked by
arich
1975
FORD F-250
How Do You Replace The Ignition Switch, Lost Keys
Asked by
conniejean42
3 IMAGES
1997
FORD F-250
VIEW MORE
SPONSORED LINKS
Battery Replacement Ford
Battery Replacement Guide
Online car repair manuals
