How do you remove a frozen bolt?
BOB W 1967
I have a 1996 ford windstar w/125000 miles on it 3.0 lt. I was attemping to repair my brakes( new pads and rotors )I removed the pads ok then I had to remove the caliper mounting bracket to remove the old rotors.I had a very hard time with the top bolt but finally got it. The bottom bolt was a different story after trying just about everything,heat wd some new stuff the parts guy told me about.Nothing worked and I rounded the bolt really bad.NOW WHAT DO I DO?
Jun 8, 2007 at 7:25 AM
CRAIGFL
  • 89 POSTS
I don't like things "cherry red" because that's hot enough to change the heat treatment of a part if it was heat treated. The first thing I would do is to wire brush clean any exposed threads that you can see. Then I'd get my can of KROIL ( penetrant that creeps into very small gaps) and lubricate liberally for at least a day or two. Since the head is rounded, we need to know if cleaning up the corners and using a 6pt socket(or maybe grind down to a smaller metric one)--- whatever works best. Then get out that 4 foot pipe to put over your breaker bar and try it. I'd be surprised if you would need any heat at all...
Jun 8, 2007 at 8:35 AM
