headlights
CAL
Ford f250 crew cab diesel 2005 68K. The truck has a headlight out on the right side but only on the low beam. I have checked the fuse and bulb. Some one said it could be a relay. Where is the relay located for the low beam right side? If not a relay problem is it maybe a short in the wire or what else?
Oct 27, 2007 at 2:30 AM
MERLIN2021
  • 17,250 POSTS
Try checking the ground wire on that side...Black!
Oct 27, 2007 at 2:36 AM
CAL
Thanks, this would be out in the location of the light
Is there a relay I should be checking?
Oct 27, 2007 at 2:46 AM
MERLIN2021
  • 17,250 POSTS
If the relay were bad, both would be out...it's either the bulb or the ground, try swapping the one that works into that socket as a test! If you have a test light unplug the pigtail from the bulb, turn lights on and test the colored wires, 1 is high the other is low, black is ground...
Oct 27, 2007 at 2:56 AM
CAL
Are they grounded separately or do they share a common ground? If I have to pull a new wire I figure to come off the rely and if so where in the H@!# is it located.
Oct 27, 2007 at 3:48 AM
MERLIN2021
  • 17,250 POSTS
If it's a bad ground, you can re ground them seperatly....
Oct 27, 2007 at 8:53 AM
