Four Wheel Drive Problem- 4HI
LARSON_EIGHT
  • 6 POSTS
I own a 1997 F-250 7.3L powerstroke turbo diesel with 303,000 miles. the truck runs and drives great. ibut i'm having trouble with my 4hi. i try to shift from 2hi to 4hi and it just goes right past and slips into nuetral. my 4 low works fine but if i do get it into 4hi i just can't get it to stay in and it pops out. Both front hubs are fine. i took apart my transfer case and everyting looks pretty good, just a little normal wear. the transfer case is a borg and warner 4407 and i'm having trouble finding info and diagrams of it. if anyone could help me out i would appreciate it.
Apr 17, 2007 at 2:11 PM
2CARPRO JACK
  • 11,533 POSTS
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Here you will find a complete schematic of your t-case. Sounds like the shift bushings in the t-case are worn and not fully engaging it. They are just plastic bushings and they wear. Also check the shifter bushings to be sure it is throwing all the way
Feb 20, 2008 at 11:20 PM
