Cigarette lighter
RAYLENE21
Ford Ranger 1991, 250 000 miles, 4 cylinder. My question is about the cigarette lighter in my truck, it will work with the function to light cigarettes however, i cannot plug things into it to work such as a componant for an ipod. I was wondering if you had any suggestions?
Thanks a bunch
Jan 20, 2007 at 4:45 AM
SLIMDONUTPIMP
  • 7 POSTS
The prongs inside the socket have lost there tension, or there is alot of corrosion to the socket it can be replaced easily and inexpensively from any local part store, note the nicotine and tar from the cigs will cause them to go bad sooner
Jan 20, 2007 at 5:15 AM
RICEJM
I have a F250 Ford HD. I need to replace the lighter socket but can't figure out how to remove it. Do I have to remove that part of the dash?
Mar 2, 2007 at 9:27 AM
MIKE H R
  • 3,094 POSTS
the sides of the i pot need to be spread out a little, the prongs on the inside of the lighter don't hold the i pod connection in but the sides of the adapter
hold it in, the center is for the power clean the end off, you could also use a light sandpaper to clean it.
Mar 2, 2007 at 9:36 AM
MIKE H R
  • 3,094 POSTS
the back of the lighter screws over the lighter socket . remove wires going to the lighter, the unscrew the back letting the lighter socket come out the front sometimes it is hard to get it started to unscrew.
Mar 2, 2007 at 9:44 AM
RICEJM
[quote:cf40cf6f2f="M_J_RITZEL"]the back of the lighter screws over the lighter socket . remove wires going to the lighter, the unscrew the back letting the lighter socket come out the front sometimes it is hard to get it started to unscrew.[/quote:cf40cf6f2f]
I got a new socket but neither of them screw out. They snap in and I can't figure out how to get the plastic snaps over the opening.
Mar 2, 2007 at 10:00 AM
