2008 Ford F250 diesel in a gas burner
OILFIELDARK
Engine Performance problem
2008 Ford F250 V8 Four Wheel Drive Automatic
yes stupid as it is we filled it completely full of diesel fuel we replace plugs filters etc... and it ran good for two days then it died and we cant get it started again
Jan 15, 2010 at 2:01 PM
RACEFAN966
  • 5,029 POSTS
Ok so tell me what all have you done at this point? Have you drained the tank or tanks and refill with gas? Did you change the fuel filter? How did the plugs look? If all looks good then check for fuel pressure. You may have to change the fuel filter again. Get back to me with the needed info and we will go from there.
Jan 16, 2010 at 1:06 AM
