2008 Ford F250
2008 FORD F-250
58,780 MILES • V12 • 4WD • AUTOMATIC
KAYENTA
SCAN CODES KEPT POPPING UP #P0430- catalyst system. what's needs to be done to have it go away? also the engine not A V12. it's V10, also this vehicle is on it's third fuel pump, gasoline never went below 1/4 of tank.
Aug 13, 2010 at 7:17 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Means CAT on bank two is below effeciency either due to deteroiation,exhaust leak,leaded fuel use or fuel pressure too high. Has fuel pressure been checked to see if it is correct? may explain code andpump deaths.
Let me know
Thanks for donate
Aug 13, 2010 at 7:49 AM
