2007 Ford F250 Timing
98,000 MILES • V8 • 4WD • AUTOMATIC
CARRSHE3
This vehicle is a 5.4liter. The engine runs badly, back firing, no power , the more fuel you give it the worse it runs. We changed spark plugs, individual coils, cam shaft sensors. The cam shaft is in time with the crank shaft. I am wondering about the timing phaser or what else could cause this. When calling the ford dealership they are not aware of the timing phaser being a problem.
It is also throwing codes of #1,3 and 6 cylinders misfiring, Misfire at start up and erratic timing.
Feb 25, 2010 at 9:48 AM
  • 75,988 POSTS
Engine running rough or misfiring can be caused by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Feb 25, 2010 at 10:30 AM
