I went out one morning and had no low beams (I have high beams and I can flash the high beams). The day before the truck was in the shop for warranty work, including: wheel hubs and a tension pulley. So far, I have checked:
- bulbs good
- fuses good
- replaced headlight switch
- tested and found no low beam power to headlight sockets
Any suggestions? Thank you. My phone number is (410) 977-3911 if you want to call.
- bulbs good
- fuses good
Sep 12, 2010 at 2:24 AM
