2005 Ford F250 Turn Signal and Brake Light
2005 FORD F-250
ADIGITLESS
Electrical problem
2005 Ford F250 V8 Four Wheel Drive Automatic
On my 2005 Ford F250, my left turn signal began flashing rapidly and my driver's side brake light went out at the same time. Are they linked together as an early warning. Any ideas as to if it is a fuse or a bulb that might be out?
Jun 19, 2008 at 10:48 AM
Check the bulb and if its not it come on back-
Jun 19, 2008 at 11:10 AM
JIMOK
same problem on a 2001, bulb is good, #1 7.5amp fuse under hood is good, & #13 20amp under dash is good....Any suggestions?
May 16, 2012 at 6:11 PM
